- Joined
- Nov 5, 2015
- Messages
- 645
- Reaction score
- 184
- Age
- 58
Ok I am not useing copper cables.what I did use was cables from my old Hyperion puffed and dismantled batt.Interesting. I was able to get the pos and neg tabs soldered together no problem but the copper wire doesn't bond to the aluminum tab. I tried some light sanding on the tab but no luck. Maybe tomorrow I'll try a little solvent on a qtip. Anyways, I have some aluminum solder coming in Monday if that doesn't work.
I plan to charge them as 2 separate 2S packs. I haven't done the math yet to determine the proper charge power but I think 1C on a 4480 mAh pack is about 4.4A. I'm not going to try and push it with the charging. I'll also look at the DJI charger and see what that's doing to compare.
I have shrink wrap and everything. Ready to complete the job but I just want to make sure I have a proper bond on those tabs.
I'm going to make a series Y cable to combine the 2 packs and they will plug into my battery. Leaving the other connection empty on the FPV customs battery mod.
