Downgrading firmware on P3P from 1.11.20 to 1.5.0011 May 2020
Victoria B.C. Canada
I have acquired a P3 Pro that has Firmware 1.11.20
I have another P3 Pro that I was able downgrade from 1.09 to 1.50.0011 Thanks to the Process from . Downgrading firmware on P3P from 1.10.9 to 1.7.6
The above process was (last updated: 2017/8/23), and I haven't found anything more recent.
The Issue is that I haven't been able to find a firmware .bin to be the first step downgrade.
Thats the in between .bin file from 1.11..20 and 10.9.6
I'm concerned that I could brick it if I don't do this incorrectly AND I wonder if DJI has DOWNGRADE PROOFED with 1.11.20
So the questions are:
1. " Are there Any New Methods to Downgrade P3's?"
2. " If required Where can I get that "IN BETWEEN" >bin file?"
UPDATE
1. Found all the firmware for every DJI Product ----
2. I have not found any other Methods of Downgrading P3 's other than the tedious Step Method.
So the Only Remaining Question of the DAY is
"Is it SAFE to use the Manual Method on Version 1.11.20 to Downgrade to 1.11.0010 then the next one and the next one etc."
As far as I know, there aren’t any versions between 1.10 and 1.11. You can find many FW version bin files and the release notes here.
One note about 1.5 which you said you have on your other P3. 1.5 is a known bad version and it is the only firmware you should not use. It includes a bug that could allow the battery to shut off mid-flight. At the time, we routinely recommended not using 1.5.
Reactions: JoBe and 3rdof5
Yes, this is correct, 1.5 is flawed. It was out only a couple weeks in late 2015 when DJI quickly fixed the issue that crashed a lot of drones. 1.6 was the fix to the motor shutoff during mid-flight issue, which mostly occurred during cold weather, or someone starting up the motors and taking off again with a half charged battery. However, the 1.6 version ADDED auto throttle limitations after the single cell voltage got below 3.6V. At 3.6V the voltage character color changes from green to orange. This means you cannot ascend as fast, or fly as fast, compared to a fully charged battery. You really want version 1.6 or later, given the battery limitation in P3P.
Reactions: JoBe and Greybush
What is the best combination in the Phantom 3 Pro?
maximum possible range?
In terms of stability?
And without restrictions? and without geofencing (no-fly zones)?
My best one is:
Android: App GO 2.4.3
RC: 1.5.80
Firmware: V. 1.04.0010
Is there any better?
Hi Thanks for your reply and the advisory on the the 1.5.
I have suspended any further firmware changes after I upgrade to 1.06.0000
Hi,
having the same question as @Brad Neill. Is there any recommended way how to downgrade the latest 01.11.0020 to any firmware below? Because downgrade were possible in the past I have just installed this firmware after it got released some years ago without reading the changelog carefully.
Thanks
I remember there were threads about downgrade, you must've found a wrong one if there are no answers.
That's news to me. As far as I remember (sine 01.07.x), the Ambarella application (which is responsible for upgrade process) compared version numbers and only allowed modules to go up with versions.
If you're not sure what I mean about the modules, read here:
OGs wiki - introduction
For the info on downgrading:
O-Gs dji-firmware-tools discussion on P3X dowgrade
Hi @quaddamage and thanks. Normally I read every release note before I upgrade something. Sometime there was clearly mention "The firmware can be downgraded to ..." e. g. here in this one.
I should only play with firmware downgrades when I'm sure that I'm able to recover what ever might fail trying this or if I'm okay loosing the whole device. I'm not ready to accept this. Better building a seperate, more open-source drone from scratch or based on old DJI parts I still have.
muskansahu
