DM36x initialization passed!
UBL Product Vesion : DJI-GSP-UBL-1.0-rc10(2014-08-15)
Dji UBL Version: 1.51(Aug 15 2014 - 17:05:12)
Booting Catalog Boot Loader
BootMode = NAND
Starting NAND Copy...
Valid magicnum, 0xA1ACED66, found in block 0x00000019.
Uboot Checksum:0x7E25B44B
Actua Checksum:0x7E25B44B
U-Boot Product Vesion : DJI-GSP-Uboot-1.0-rc4(2014-07-23)
U-Boot 2010.12-rc2-svn-Dji (Jul 23 2014 - 11:14:40)
Cores: ARM 432 MHz
DDR: 297 MHz
I2C: ready
DRAM: 128 MiB
NAND: 128 MiB
Bad block table found at page 65472, version 0x01
Bad block table found at page 65408, version 0x01
Use the first environment
Net: Ethernet PHY: GENERIC @ 0xff
DaVinci-EMAC
Press ESC to abort autoboot in 1 seconds
Loading from nand0, offset 0x4a0000
** Unknown image type
Wrong Image Format for bootm command
ERROR: can't get kernel image!
Loading from nand0, offset 0x900000
Image Name: Linux-2.6.32.17-davinci1
Created: 2014-04-09 12:21:58 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 3823424 Bytes = 3.6 MiB
Load Address: 80008000
Entry Point: 80008000
## Booting kernel from Legacy Image at 80700000 ...
Loading Kernel Image ... OK
OK
Starting kernel ...
[ 0.000000] Kernel Product Vesion : DJI-Kernel-1.0-rc2
[ 0.000000] Linux version 2.6.32.17-davinci1 (root@ubuntu) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) )
#6 PREEMPT Wed Apr 9 05:21:55 PDT 2014
[ 0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=00053177
[ 0.000000] CPU: VIVT data cache, VIVT instruction cache
[ 0.000000] Machine: DaVinci DM36x EVM
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] DaVinci dm36x_rev1.2 variant 0x8
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping off. Total pages: 12192
[ 0.000000] Kernel command line: console=ttyS0,115200n8 rw dm365_imp.oper_mode=0 video=davincifb:vid0=0,0:vid1=0,0
sd0=0,0
sd1=0,0 mem=48MB davinci_enc_mngr.ch0_output=COMPOSITE davinci_enc_mngr.ch0_mode=pal ubi.mtd=2,2048
root=ubi0:rootfs rootfstype=ubifs ip=off lpj=1077248
[ 0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Memory: 48MB = 48MB total
[ 0.000000] Memory: 44784KB available (3456K code, 310K data, 112K init, 0K highmem)
[ 0.000000] SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:245
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Calibrating delay loop (skipped) preset value.. 215.44 BogoMIPS (lpj=1077248)
[ 0.000000] Mount-cache hash table entries: 512
[ 0.000000] CPU: Testing write buffer coherency: ok
[ 0.000000] DaVinci: 8 gpio irqs
[ 0.000000] NET: Registered protocol family 16
[ 0.070000] EVM: tvp5146 SD video input
[ 0.130000] bio: create slab <bio-0> at 0
[ 0.130000] DM365 IPIPE initialized in Continuous mode
[ 0.140000] usbcore: registered new interface driver usbfs
[ 0.140000] usbcore: registered new interface driver hub
[ 0.140000] usbcore: registered new device driver usb
[ 0.140000] vpss vpss: dm365_vpss vpss probed
[ 0.140000] vpss vpss: dm365_vpss vpss probe success
[ 0.140000] dm365_afew_hw_init
[ 0.150000] ch0 default output "COMPOSITE", mode "PAL"
[ 0.150000] VPBE Encoder Initialized
[ 0.150000] cfg80211: Using static regulatory domain info
[ 0.150000] cfg80211: Regulatory domain: US
[ 0.150000] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 0.150000] (2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2700 mBm)
[ 0.150000] (5170000 KHz - 5190000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 0.150000] (5190000 KHz - 5210000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 0.150000] (5210000 KHz - 5230000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 0.150000] (5230000 KHz - 5330000 KHz @ 40000 KHz), (600 mBi, 2300 mBm)
[ 0.150000] (5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 3000 mBm)
[ 0.150000] cfg80211: Calling CRDA for country: US
[ 0.150000] LogicPD encoder initialized
[ 0.150000] Switching to clocksource timer0_1
[ 0.160000] musb_hdrc: version 6.0, cppi-dma, host, debug=0
[ 0.180000] musb_hdrc: USB Host mode controller at fec64000 using DMA, IRQ 12
[ 0.180000] musb_hdrc musb_hdrc: MUSB HDRC host driver
[ 0.180000] musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
[ 0.180000] usb usb1: configuration #1 chosen from 1 choice
[ 0.180000] hub 1-0:1.0: USB hub found
[ 0.180000] hub 1-0:1.0: 1 port detected
[ 0.180000] NET: Registered protocol family 2
[ 0.180000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.180000] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.180000] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.180000] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.180000] TCP reno registered
[ 0.180000] NET: Registered protocol family 1
[ 0.180000] RPC: Registered udp transport module.
[ 0.180000] RPC: Registered tcp transport module.
[ 0.180000] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.190000] JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.190000] msgmni has been set to 87
[ 0.200000] alg: No test for stdrng (krng)
[ 0.200000] io scheduler noop registered (default)
[ 0.260000] DM365 IPIPEIF probed
[ 0.260000] imp serializer initialized
[ 0.260000] davinci_previewer initialized
[ 0.270000] davinci_resizer initialized
[ 0.270000] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
[ 0.270000] serial8250.0: ttyS0 at MMIO 0x1c20000 (irq = 40) is a 16550A
[ 0.680000] davinci_interrupt 368: VBUS error workaround (delay coming)
[ 0.690000] console [ttyS0] enabled
[ 0.700000] serial8250.0: ttyS1 at MMIO 0x1d06000 (irq = 41) is a 16550A
[ 0.710000] brd: module loaded
[ 0.710000] NAND device: Manufacturer ID: 0x2c, Chip ID: 0xf1 (Micron NAND 128MiB 3,3V 8-bit)
[ 0.720000] Creating 4 MTD partitions on "davinci_nand.0":
[ 0.730000] 0x000000000000-0x0000004a0000 : "bootloader"
[ 0.740000] 0x0000004a0000-0x000000e00000 : "kernel"
[ 0.740000] 0x000000e00000-0x000007f00000 : "filesystem"
[ 0.750000] 0x000000000000-0x000008000000 : "all"
[ 0.760000] davinci_nand davinci_nand.0: controller rev. 2.3
[ 0.770000] UBI: attaching mtd2 to ubi0
[ 0.770000] UBI: physical eraseblock size: 131072 bytes (128 KiB)
[ 0.780000] UBI: logical eraseblock size: 126976 bytes
[ 0.790000] UBI: smallest flash I/O unit: 2048
[ 0.790000] UBI: sub-page size: 512
[ 0.790000] UBI: VID header offset: 2048 (aligned 2048)
[ 0.800000] UBI: data offset: 4096
[ 1.290000] UBI: attached mtd2 to ubi0
[ 1.290000] UBI: MTD device name: "filesystem"
[ 1.290000] UBI: MTD device size: 113 MiB
[ 1.300000] UBI: number of good PEBs: 904
[ 1.300000] UBI: number of bad PEBs: 0
[ 1.310000] UBI: max. allowed volumes: 128
[ 1.310000] UBI: wear-leveling threshold: 4096
[ 1.320000] UBI: number of internal volumes: 1
[ 1.320000] UBI: number of user volumes: 1
[ 1.330000] UBI: available PEBs: 0
[ 1.330000] UBI: total number of reserved PEBs: 904
[ 1.340000] UBI: number of PEBs reserved for bad PEB handling: 9
[ 1.340000] UBI: max/mean erase counter: 3/1
[ 1.350000] UBI: image sequence number: 1093809597
[ 1.350000] UBI: background thread "ubi_bgt0d" started, PID 308
[ 1.360000] console [netcon0] enabled
[ 1.360000] netconsole: network logging started
[ 1.370000] i2c /dev entries driver
[ 1.370000] Linux video capture interface: v2.00
[ 1.380000] vpfe_init
[ 1.380000] vpfe-capture: vpss clock vpss_master enabled
[ 1.390000] vpfe-capture vpfe-capture: v4l2 device registered
[ 1.400000] vpfe-capture vpfe-capture: video device registered
[ 1.440000] EVM: switch to tvp5151 cvbs video input
[ 1.440000] vpfe-capture vpfe-capture: v4l2 sub device tvp5150 registered
[ 1.450000] EVM: switch to it6604 hdmi video input
[ 1.460000] vpfe-capture vpfe-capture: v4l2 sub device cat6023 register fails
[ 1.460000] vpfe_register_ccdc_device: DM365 ISIF
[ 1.470000] DM365 ISIF is registered with vpfe.
[ 1.480000] Trying to register davinci display video device.
[ 1.480000] layer=c108d800,layer->video_dev=c108d964
[ 1.490000] Trying to register davinci display video device.
[ 1.490000] layer=c108dc00,layer->video_dev=c108dd64
[ 1.500000] davinci_init
aVinci V4L2 Display Driver V1.0 loaded
[ 1.510000] watchdog watchdog: heartbeat 1 sec
[ 1.510000] TCP cubic registered
[ 1.510000] NET: Registered protocol family 17
[ 1.520000] lib80211: common routines for IEEE802.11 drivers
[ 1.530000] Clocks: disable unused mmcsd0
[ 1.530000] Clocks: disable unused mmcsd1
[ 1.530000] Clocks: disable unused spi0
[ 1.530000] Clocks: disable unused spi1
[ 1.530000] Clocks: disable unused spi2
[ 1.530000] Clocks: disable unused spi3
[ 1.530000] Clocks: disable unused spi4
[ 1.530000] Clocks: disable unused pwm0
[ 1.530000] Clocks: disable unused pwm1
[ 1.530000] Clocks: disable unused pwm2
[ 1.530000] Clocks: disable unused pwm3
[ 1.530000] Clocks: disable unused timer1
[ 1.530000] Clocks: disable unused timer3
[ 1.530000] Clocks: disable unused emac
[ 1.530000] Clocks: disable unused voice_codec
[ 1.530000] Clocks: disable unused asp0
[ 1.530000] Clocks: disable unused rto
[ 1.530000] Clocks: disable unused mjcp
[ 1.600000] nnnn===0
[ 1.600000] davinci_emac_probe: using random MAC addr: 4e:10:87:0a:b8:16
[ 1.610000] emac-mii: probed
[ 1.650000] UBIFS: recovery needed
[ 1.690000] UBIFS: recovery completed
[ 1.690000] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[ 1.700000] UBIFS: file system size: 110342144 bytes (107756 KiB, 105 MiB, 869 LEBs)
[ 1.710000] UBIFS: journal size: 9023488 bytes (8812 KiB, 8 MiB, 72 LEBs)
[ 1.710000] UBIFS: media format: w4/r0 (latest is w4/r0)
[ 1.720000] UBIFS: default compressor: lzo
[ 1.720000] UBIFS: reserved for root: 0 bytes (0 KiB)
[ 1.730000] VFS: Mounted root (ubifs filesystem) on device 0:13.
[ 1.740000] Freeing init memory: 112K
Runing /etc/init.d/rcS
[ 2.830000] davinci_interrupt 368: VBUS error workaround (delay coming)
/opt/dji/bin/sshenable: line 2: ./eth0config: not found
sulogin: no password entry for root
login[413]: root login on 'ttyS0'
#Process /etc/profile...
root@Dji-Pro:~# [ 4.980000] davinci_interrupt 368: VBUS error workaround (delay coming)
[ 6.820000] CMEMK module: built on Nov 27 2013 at 14:02:36
[ 6.840000] Reference Linux version 2.6.32
[ 6.840000] File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
[ 6.860000] allocated heap buffer 0xc7000000 of size 0x2456000
[ 6.890000] heap fallback enabled - will try heap if pool buffer is not available
[ 6.890000] CMEM Range Overlaps Kernel Physical - allowing overlap
[ 6.910000] CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x83000000)
[ 6.910000] cmemk initialized
[ 6.940000] IRQK module: built on Nov 27 2013 at 14:02:41
[ 6.960000] Reference Linux version 2.6.32
[ 6.960000] File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/irq/src/module/irqk.c
[ 6.980000] irqk initialized
[ 7.030000] EDMAK module: built on Nov 27 2013 at 14:02:45
[ 7.030000] Reference Linux version 2.6.32
[ 7.050000] File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/edma/src/module/edmak.c
[ 7.130000] davinci_interrupt 368: VBUS error workaround (delay coming)
pdi=0
pdi=441
Encode demo started.
[ 7.280000] davinci_resizer davinci_resizer.2: RSZ_G_CONFIG:0:1:124
[ 7.280000] davinci_previewer davinci_previewer.2: ipipe_set_preview_config
[ 7.290000] vpfe-capture vpfe-capture: IPIPE Chained
[ 7.300000] vpfe-capture vpfe-capture: Resizer present
detectVide to cr[ 7.300000] vpfe_s_input
eate
fd = hCapture->fd
Composite input selected
[ 7.350000] EVM: switch to tvp5151 cvbs video input
listening.****Failed to set video input to 0 (Invalid argument)
Cannot111 open captureDevice
Error: Failed to create capture device. Is video input connected?
video.c: semkey1: 852613 semkey1: 852614 shmkey: -1
params->maxFrameRate ==30000
Venc1.c : minNumOutBufs 2, minOutBufSize[0] 460800, minOutBufSize[1] 800
video.c: minNumOutBufs 2
osdThrFxn: process ID is 444 ***********
ctrlThrFxn: process ID is 440 ***********
**************************************** pid of Xorg :-1 ==-1
****************************************************************************************************************killall: encode: no process killed
[ 9.360000] cmemk unregistered
[ 9.420000] irqk unregistered
[ 10.660000] CMEMK module: built on Nov 27 2013 at 14:02:36
[ 10.660000] Reference Linux version 2.6.32
[ 10.680000] File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
[ 10.700000] allocated heap buffer 0xc7000000 of size 0x2456000
[ 10.720000] heap fallback enabled - will try heap if pool buffer is not available
[ 10.730000] CMEM Range Overlaps Kernel Physical - allowing overlap
[ 10.740000] CMEM phys_start (0x1000) overlaps kernel (0x80000000 -> 0x83000000)
[ 10.750000] cmemk initialized
[ 10.780000] IRQK module: built on Nov 27 2013 at 14:02:41
[ 10.780000] Reference Linux version 2.6.32
[ 10.800000] File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/irq/src/module/irqk.c
[ 10.820000] irqk initialized
[ 10.860000] EDMAK module: built on Nov 27 2013 at 14:02:45
[ 10.880000] Reference Linux version 2.6.32
[ 10.880000] File /home/u/dm368/dvsdk_dm368_4_02_00_06/linuxutils_2_26_01_02/packages/ti/sdo/linuxutils/edma/src/module/edmak.c
pdi=490
[ 11.000000] davinci_resizer davinci_resizer.2: RSZ_G_CONFIG:0:1:124
[ 11.010000] davinci_previewer davinci_previewer.2: ipipe_set_preview_config
[ 11.020000] vpfe-capture vpfe-capture: IPIPE Chained
[ 11.020000] vpfe-capture vpfe-capture: Resizer present
detectVide to cr[ 11.030000] vpfe_s_input
eate
fd = hCapture->fd
pdi=0
[ 11.070000] EVM: switch to tvp5151 cvbs video input
listening.**************Failed to set video input to 0 (Invalid argument)
osdThrFxn: process ID is 493 ***********
ctrlThrFxn: process ID is 489 ***********
********************************************************** pid of Xorg :-1 ==441
