DJI go 4.0 keeps chashing
Hi my DJI go 4.0 app keeps crashing sometimes after 10 minutes, sometimes 15 minutes, it seems to happen when I change from video to photo there's a slight pause before changes and then 15 seconds after the app crashes as a result I lose on my flight information anybody got any ideas I'm using the Galaxy Tab S3 thank you
Which version of DJI GO are you using?
What did you change between now and when all last worked as expected?
You can find the DJI GO version in the "General Settings" --> "About" section of DJI GO.
Don't know if this is related, I have problems where older DJI Go app will not connect, only rarely to P3P. It worked initially, but now does not. Litchi also does not connect. The older 8 inch Tab A does connect. Both have Nougat OS.
I have the latest version from the iOS app store and it hasn't crashed once. I also delete my cache files all the time and always run the app by itself with no other apps running. All my flight gear is using the latest firmware. Goggles are coming soon, so hopefully I won't need to use the iPad much longer. :)
robvalduga
