- Joined
- Feb 20, 2019
- Messages
- 78
- Reaction score
- 25
- Age
- 43
Im trying to update my p4p+ controller it keeps beeping when turn on and sometimes it doesn't when I turn on the drone first then the controller 2nd. I did calibration on the controller but it still beeps when turn on. The map is in Chinese too. The drone is on firmware few yrs ago.When I had my P1 a couple years ago my laptop ran Windows 7. I then bought a new laptop running Windows 10 and had that problem which resulted in the same message because at least at that time DJI did not update the ***-istant to run on Win10 because the P2 and probably P3 were already on the market so I wound up flying uncallibrated and shortly there after it flew away on me and I never found it. I am not sure which model you are running but in my case I should have but an old laptop running Vista or Win 7 from someone that would have been dedicated to the drone, but whatcha gonna do?
Yeah I tried many things like RC first then Controller.They controller will beep when it is not connected to the aircraft.
Well found out the truth. DJI Assistant 2 does not really work with Windows 10. I was suggested DJI to use Windows 8/7. Wow pretty backward.I have a laptop running win 7 pro 64bit and Dji assistant runs fine with my P2V+
Ya I have a few older programs that don't play well with win10. So I reverted back to 7 on my laptop.Well found out the truth. DJI Assistant 2 does not really work with Windows 10. I was suggested DJI to use Windows 8/7. Wow pretty backward.
yeah that works fine, although Windows 10 has trouble with installing the driver for the RC asst.I have a laptop running win 7 pro 64bit and Dji assistant runs fine with my P2V+
Here's a quote from DJI customer service email. "The issue about the DJI Assistant 2 wherein it's blocking the app, our Engineers have found the cause of the issue and are working on it. During this period, you may install or run DJI Assistant 2 software using a computer with Windows 7/8 or Mac. "LOL Post 3, the system censored the name of the DJI program
err yes it does, I’ve got the win10 64bit and disabling driver checking let’s it work
It works perfectly fine with windows 10! You must disable 'Driver Signature Enforcement'. Then you'll be good.Well found out the truth. DJI Assistant 2 does not really work with Windows 10. I was suggested DJI to use Windows 8/7. Wow pretty backward.
It's very very easy. How to: Disable driver signature enforcement on Windows 10Where does one go to disable 'Driver Signature Enforcement'? Thanks.
Google “disable driver signature enforcement”.
