Disable GoPro OSD on FPV
How would I go about disabling the GoPro OSD so it only shows the iOSD OSD?
See example with GoPro highlighted in yellow.
Select the wrench icon on the GoPro menu and find OSD and turn it off. Can't miss it.
Yup easy to turn off but you might turn it back on the first time you forget to hit record! I like having the red camera in the upper left telling me that its recording even though the rest of the GoPro OSD I couldn't care less about
Same here, while it's all cluttered up and there' some overlap, I've found it quite beneficial to be able to see the GoPro information. - making sure it's set to the right settings, as well as making sure it IS recording!
plus when filming, the GoPro timer can give you a rough idea of flight time.
can't remember where but it's in gopro settings. I disabled mine. seriously ... it's not like you can change it on the fly . you pre-set settings and hit the record button before you launch.
