Difference Between GL300B And GL300C Controllers
Cupertino, California
I am just getting more, and more confused about the controller. After I received a defective unit the first time, and it fell out of the sky on first flight. They sent me a complete replacement. But I used to have the GL300C controller, and the replacement remote prints: GL300B. What is the difference between C and B? I am quite confused. Thanks. The difference is probably not big, and doesn't change anything, but I am just curious. Anyone knows?
It's not better. I have both B and C versions. Exactly the same.
[quote uid=21954 name="StevenQX" post=726401]Hi @GadgetGuy, first of all thanks for the report then a small question. I see that you have a lot of knoledge on p3 RC, could i ask you which model is the best one in terms of range of control and video stream? 300A or B?[/QUOTE]<br />GL300A and GL300B should be the same control power output, at .380 watts each.<br />GL300C is the worst, at 20% less, at .303 watts.<br />The video power output comes from the aircraft, and not the RC.<br />WM330A P4 is .598 watts, while the original W323 P3P is .746 watts.
This is the answer i had from gadgetguy about rc
Reactions: Jim Canada
My phantom came with a GL300B. The halves of the remote were separated and loose from the factory. The internal posts for the screws were broken before I ever took it apart.
When doing the DBS mod, the tip of the antenna plug broke off in the board and I had to replace the RC. I ordered a GL300C remote off ebay. The case and plastic screw posts were much better and were not broken out of the box. They didn't break when I installed DBS either. Past that the remote seems the same to me.
Nothing to be confused about! 999 out of 1000 flyers wont benefit from one over the other
Reactions: snowy23
I have a GL300B controller for sale at a reasonable price of $109 postage paid to US destinations.. Works great. Like new condition. Call me at 858-663-6672 Mark
So for a person who likes to modify and get the best bang for my buck if I were to be adding a clean install kit and nice itelite panel, I would be getting a better transmit snd and rcv with a gl300a/b vs. gl300c? Minus video since transmit power comes from the bird right? I'm new and gathering info from your posts just want to make sure.
padanje
