Difference Between GL300B And GL300C Controllers
Discussion in 'Pro/Adv Discussion' started by Eric1084, Feb 7, 2016.
  1. Eric1084
    Cupertino, California
    I am just getting more, and more confused about the controller. After I received a defective unit the first time, and it fell out of the sky on first flight. They sent me a complete replacement. But I used to have the GL300C controller, and the replacement remote prints: GL300B. What is the difference between C and B? I am quite confused. Thanks. The difference is probably not big, and doesn't change anything, but I am just curious. Anyone knows?
  2. Donald Johansen
    Ditto wish I knew the difference as well.....
  3. StevenQX
    Italy
    The B is better because have 20% more power.
  4. ianwood
    ianwood Taco Wrangler
    Staff Member
    Lost Angeles
    It's not better. I have both B and C versions. Exactly the same.
  5. StevenQX
    Italy
    [quote uid=21954 name="StevenQX" post=726401]Hi @GadgetGuy, first of all thanks for the report then a small question. I see that you have a lot of knoledge on p3 RC, could i ask you which model is the best one in terms of range of control and video stream? 300A or B?[/QUOTE]<br />GL300A and GL300B should be the same control power output, at .380 watts each.<br />GL300C is the worst, at 20% less, at .303 watts.<br />The video power output comes from the aircraft, and not the RC.<br />WM330A P4 is .598 watts, while the original W323 P3P is .746 watts.
    This is the answer i had from gadgetguy about rc
  6. TK P3A
    My phantom came with a GL300B. The halves of the remote were separated and loose from the factory. The internal posts for the screws were broken before I ever took it apart.
    When doing the DBS mod, the tip of the antenna plug broke off in the board and I had to replace the RC. I ordered a GL300C remote off ebay. The case and plastic screw posts were much better and were not broken out of the box. They didn't break when I installed DBS either. Past that the remote seems the same to me.
  7. dirtybum
    Nothing to be confused about! 999 out of 1000 flyers wont benefit from one over the other
Similar Threads - Difference Between GL300B Forum Date
The difference between the English & China version batteries Pro/Adv Discussion May 15, 2017
Difference between p3 and p4 motors Phantom 4 Pro Discussion Apr 26, 2017
Difference between P3P and P4? Pro/Adv Discussion Mar 23, 2017
What is the difference between DJI intelligent battery part # 133 vs part # 12 ??? Pro/Adv Discussion Mar 7, 2017
What is the Difference between Airspace Authorization and Airspace Waiver? Class D Rules and Regulations Jan 16, 2017
