I've been leaving it on mine.
I deleted mine since if you keep it on it keeps trying to update the firmware and fails since you have the latest firmware installed. It also writes this message to the text file on your SD card.
I think that is a waste of memory card, you can save it on your computer and use that memory card for videos and photosI'm using the SD card that came w/ the bird solely for firmware updates.
I have so many SD cards laying around between my Pi's, Cubox's, Phantoms, I don't really notice.I think that is a waste of memory card, you can save it on your computer and use that memory card for videos and photos
Wonder why DJI has not stated anything about this.....
Upgrade package file... this would be the zip file and the P3 well ignore this file. It's not the bin file. If the bin file is left in the root of the SD card the P3 will attempt to update each time it's turned on.This snippet is from the .pdf file from DJI for updating firmware:
Updating Intelligent Flight Battery Firmware
The Intelligent Flight Battery is upgraded during the aircraft firmware upgrade process. It is recommended to keep the upgrade package files in your SD card. The upgrade will start automatically after power cycling the aircraft.
That certainly sounds to me like - when you get a new battery, the firmware update must be "applied" to the new battery.
I've kept the latest firmware update on my SD card - just the .bin file and nothing else. Guess we won't know for sure what really happens until someone gets more batteries!
