- Joined
- Nov 27, 2016
- Messages
- 28
- Reaction score
- 2
- Age
- 71
Based on the given availability I'm thinking (having a hard time) maybe to order P4P instead of P4P+...
question: can the standard P4 controller charge an iPad Air 2?
I like the built in screen it's easy use, one button, one device to charge and not taking care if each and every device is fully charged.
Where did you get indication that P4P+ controllers are backward compatible with P4 and P3P/A? That doesn't sound right since P4P supports 5.8Ghz and the older models don't.The Phantom 4 Pro+ controller should work with the Phantom 4 Pro, Phantom 4, Phantom 3 Pro, Phantom 3 Advanced.
The P4P controllers are not backwards compatible with anything. They use a new version of Lightbridge which is not compatible with earlier Phantom models, and certainly not the Mavic since the P4P controllers support neither Occusync or WiFi.The Phantom 4 Pro+ controller should work with the Phantom 4 Pro, Phantom 4, Phantom 3 Pro, Phantom 3 Advanced. It may even control the Mavic Pro (certainly via WiFi, but not sure with OccuSync)
The CrystalSky controller is backwards compatible as well. Since the Phantom 4 Pro+ controller has similar specs to the CrystalSky controller, there is ZERO doubt that both controllers will work with many future models of the Phantom and other DJI drones.
Yes. The separate CrystalSky can plug into the USB port on the bottom of the P4P+ transmitter, which then disables the built-in screen and replaces it. Then you just need to mount the separate CrystalSky monitor over the built-in screen. Gaffers tape will certainly hold it in place, or you can find a more elegant mounting solution.
Isn't the USB connection on the back top where the HDMI is located? I don't see connectors on the bottom.Yes. The separate CrystalSky can plug into the USB port on the bottom of the P4P+ transmitter, which then disables the built-in screen and replaces it. Then you just need to mount the separate CrystalSky monitor over the built-in screen. Gaffers tape will certainly hold it in place, or you can find a more elegant mounting solution.
What method did you use to determine the latency of your iPad?The DJI propaganda about less latency isn't that much of an advantage. An iPad Mini2 gives me 180- to 220ms latency, when the P4P+ claims 180ms (I think).
This is the least latency I got.What method did you use to determine the latency of your iPad?
The USB connector is, indeed, next to the HDMI on the back lower side of the controller, which I obtusely referred to as the "bottom." This module also includes an integrated microUSB card reader, to play back and review the video from the card inside the aircraft immediately, and potentially edit it or use WiFi to share it. The separate $99 HDMI board is missing that microSD card reader. A microphone is also included on the remote for use during live streaming, if that is your thing, to narrate your flight.Isn't the USB connection on the back top where the HDMI is located? I don't see connectors on the bottom.
Personally, I see no reason to buy a P4P+ if the plan is to use a 7.9" CrystalSky display. You need the display clip of the P4P to hold the display, which you don't get with the P4P+, correct? Wouldn't we be better off buying the P4P (quicker delivery) and installing the optional HDMI module ($99) yourself (assuming you wanted to use goggles). That's $200 less and you have the clip, ready for any display. The DJI propaganda about less latency isn't that much of an advantage. An iPad Mini2 gives me 180 to 220ms latency, when the P4P+ claims 180ms (I think). We know DJI fudges numbers (P4=28min, 22mph w/OA) so it appears to me there's no tangible latency advantage.
I'm annoyed that DJI didn't include the HDMI connection on the P4P when they call this their "PRO" version. Typhoon H and Solo both have HDMI out as STANDARD! Give me a break! That module costs them less than $20 to manufacture. It doesn't affect me since I already have one I can transfer, but it's just annoying how they missed the mark, given the trivial added manufacturing cost. It just seems petty for a "PRO" version to omit this.
Keep in mind that nobody knows the price of the 7.9" Crystalsky device, it's all a guessing game right now. From a manufacturing point of view those daylight readable displays are typically cost about 2X the price for the glass, and the glass is only about 1/3 the cost of the materials for a tablet. However, manufacturing cost has nothing to do with resell price for some products. It will be up to DJI to determine the price, and I expect that to be lower than speculation from this forum. If it's too high people won't buy it, so it will be interesting to see what they introduce it for. I'll put my stake in the ground and predict it will less than $400 in 2yrs, that's my prediction. I think other manufacturers are working on similar daylight readable android devices, which will help drive costs down. I will be looking for those at CES this coming Jan. I bet I'll find some. You can find Chinese manufacturers of these hi-bright tablets today, so it's just a matter of time before we're in "flight display nirvana" that we'll need sunglasses to use. LOL....I see a lot of 'I'd rather have the 7.8" CrystalSky display over the 5.5" comments, but ya... of course... and we'd all probably 'rather' have the Inspire 2 than the P4P, but there is the little issue of cost. From all I've been able to gather the price of the 7.8" CrystalSky unit is likely to be in the $800-$1000 range, so what you have to ask yourself whether you'd also be willing to pay another $500-$700 for the larger screen... well would ya... punk?
Getting the 5.5" screen for only $300 extra is about the most cost efficient way you're gonna get into a CrystalSky display.
Yet the price of the 5.5" Crystalski screen is already included today in the price of the P4P+, along with HDMI, GPS, a microSD card reader to play back 4K drone videos on the display in the field. No guessing necessary there! It's a wonderful world!Keep in mind that nobody knows the price of the 7.9" Crystalsky device, it's all a guessing game right now. From a manufacturing point of view those daylight readable displays are typically cost about 2X the price for the glass, and the glass is only about 1/3 the cost of the materials for a tablet. However, manufacturing cost has nothing to do with resell price for some products. It will be up to DJI to determine the price, and I expect that to be lower than speculation from this forum. If it's too high people won't buy it, so it will be interesting to see what they introduce it for. I'll put my stake in the ground and predict it will less than $400 in 2yrs, that's my prediction. I think other manufacturers are working on similar daylight readable android devices, which will help drive costs down. I will be looking for those at CES this coming Jan. I bet I'll find some. You can find Chinese manufacturers of these hi-bright tablets today, so it's just a matter of time before we're in "flight display nirvana" that we'll need sunglasses to use. LOL....![]()
Well who knows, the way things are going who can predict what drones will do or cost two years out. The only problem with waiting for lower prices is when you want to fly today, not two years from now.I'll put my stake in the ground and predict it will less than $400 in 2yrs, that's my prediction.
It's only a 1080 display isn't it? I don't think anyone makes a 4K display in a tablet or laptop size yet do they? I think it will have to render a 1080 resolution for playback. I'm curious if it will choke on a 4K video. Has anyone tried to play 4K videos straight from the SD card on the nvidia K1?Yet the price of the 5.5" Crystalski screen is already included today in the price of the P4P+, along with HDMI, GPS, a microSD card reader to play back 4K drone videos on the display in the field. No guessing necessary there! It's a wonderful world!![]()
I'm a bit skeptical about that feature, as well. My iPad Pro won't even play original or edited 4K videos stored on the miniSD card with the iFlashDevice, unless they are under 2.5GB in size, and the continuous 4K video is recorded on the micro SD card in 4GB chunks. No dice, unless I manually stop and start the inflight video manually before it reaches 2.5GB per file. The P4P also touts the ability to use an xFAT file format, which should finally remove the 4GB file size limitation, if the card is 64GB or larger, so no more lost gaps in the continuous video, but the resulting file will also not be supported for viewing by the iFlashDevice. So, my guess is that only 1080p recordings will be able to be played back on the built-in screen. Hmmm. It will be one of the first things I test during my 7 day return period with DJI!It's only a 1080 display isn't it? I don't think anyone makes a 4K display in a tablet or laptop size yet do they? I think it will have to render a 1080 resolution for playback. I'm curious if it will choke on a 4K video. Has anyone tried to play 4K videos straight from the SD card on the nvidia K1?
You should get the P4P instead then. When the CrystalSky monitor is available, you'll be able to attach it to the P4P remote controller.
Thanks a lot for the info, its a pity that I cannot use the +, I'll have to buy a HDMI module...
