Cannot connect on wifi module, although i can see it
So following a guide in this forum i have enabled password protection between the repeater and the phantom. I have also configured the phantom to broadcast it's ssid, so i can see it.
Everything was working ok, but after a restart of the bird and the repeater, i can no longer connect on the wifi network of the bird using my laptop, and the repeater cannot connect on it either. So i dont have video.
The issue is that I can see the wifi network of the phantom, i try to connectg on it, i get a password prompt and enter the password. I used my phone number so I know I've got it right. After entering the password, i get a message saying "network security key mismatch"
I have tried deleting all the saved wifi networks on my laptop and tried to connect again, but unsuccessfully.
So what can i do to fix this?
thanks
Tricky one, is it possible to leave the password blank and continue, since it seems to have forgotten it?
A common default is 123456 or similar.
You might get useful info from the creator of the app which implements that modification.
Have you tried rebinding process.
It probably can't make things worse!
DonT
