I purchased the Phantom and now the AVL downlink the cables for the transmitter are wrong. the battery connector is different then whats on the battery pack for the Phantom. the Phantom has the round pins and the downlink cable has one horizontal flat bar and one vertical flat bar. it also has a 1/8th connector for the GoPro which does not fit cause the GoPro has the mini usb type. so It looks I have to do some cutting. On the transmitter cable the 1/8 plug has three sections, I rung them out and it looks like only two are used to connector that plug into the Tx (gray & purple wire). is the tip of the plug nothing?
On the Tx what is "UART" (red & brown wire)?
how can I connect the Tx power to the battery for the Phantom?
Just a little ***** here, I don't understand why the DJI downlink does not fit the DJI Phantom. There was no manual I had to spend time looking for it. It was over $200 and I have to modify cables.posting.php?mode=post&f=4#
thanks
Dennis
thanks
Dennis
