busted the gimbal pitch motor on my p3s
hi guys i just had an incident and the pitch motor for the gimbal opened up and im not sure if its possible to put it back together or needs to be replaced, nothing seems to be broken (wires or aluminum) the motor casing just opened up, it seems a bit difficult to find this part and it seems out of stock where they sell it, so my question is if its fixable or if i need to replace, also another question is if this particular part is compatible on all 3 p3 models or the standard is different, i really appreciate your help and ive been looking all over for the same question but could not, im attaching a picture so you can see my problem
thank you very much
mauricio
Those parts press together and are held together magnetically. You should replace the flat ribbon cable if it's damaged.
shimuafeni fredrik
