- Joined
- Aug 1, 2015
- Messages
- 1,754
- Reaction score
- 520
- Age
- 41
Yes, but they dont tighten as much as they are supposed to be tightened before flightDon't they self tighten as they spin?
There's metal in sidewalksYes. On a sidewalk. No metal near by.
That's the way I do it too. Over 300 miles flown and no problems.So "finger tight" as I would mean is "spin" til it stops, hold motor, lightly snug tighten the prop. Done.
That's what I did.
This looks very much like a physical loss of lift / stability i.e. something caused one or more propellers to stop generating sufficient lift. Anything more specific than that is more speculation than not.
To confirm this, there is additional data that we need. We have pitch and roll but I don't see commanded pitch and roll or stick pitch and roll. The comparison of actual, commanded, and stick is very important. If we see the FC attempting to correct external pitch and roll, then it's clear it is a loss of controlled lift event.
I guess I can see a flight controller glitch potentially causing the result. But I would really expect that kind of flaw to be evident in the logs
Actually that should make a f/c glitch even more evident. ItYou do know the a/c was flight flying straight when it began going down, don't you?
A P3 spun down from the sky 3 minutes in, most likely from a prop coming off. Now the Geeks are interpreting flight data for related events.This thread is 18 pages long. Can someone summarize the problem/solution?
Also excluded a bird strike or other mid air collision.Excluded power loss and compass calibration as the source of the problem.
Not in Oregon. Not rebar nor screen in the side walk or the driveway approach.There's metal in sidewalks
Thanks for the update. I was wondering how the CSI investigation goes so far.A P3 spun down from the sky 3 minutes in, most likely from a prop coming off. Now the Geeks are interpreting flight data for related events.
With drones, I would think pilot error would be even higher than that, due to the lack of training and knowledge of the aircraft. With regard to Phantoms, there appears to be a lot of folks flying these machines, that have little or no knowledge of an RC aircraft much less a drone.Approximately 80 percent of airplane accidents are due to human error (pilots, air traffic controllers, mechanics, etc.) and 20 percent are due to machine (equipment) failures.
Thats because most of the mechanical errors are also pushed back to being the mechanic making a mistake. Or an inspector missing something. I took my job, and the lives that depended on that job, more seriously than my own life! Thats where the phrase- "I don't make mistakes, people die when I make a mistake"- comes from.Approximately 80 percent of airplane accidents are due to human error (pilots, air traffic controllers, mechanics, etc.) and 20 percent are due to machine (equipment) failures.
Definitely looks like compass issues.
