Btu module on P2V+
Why?
The P2V+ has the down and up data stream (2 way communication) via the wifi. When you take a photo by tapping on your screen, that's the upstream data. When you see fpv/telemetry, battery info, GPS counts, that's the downstream. Ground station does not work unless you have 2 way coms.
The BTU was designed for the P2 Non Vision. The P2 Non Vision usually only had down feed (FPV) and no way to communicate back to the phantom. Most users who use BTU would only need it for Ground Station automation.
Aeria
