Auto focus now not working.
Just got my p4p and did firmware update on aircraft and rc. First day video and stills focus was perfect. However after that next 2 flight days Focus would not work for Stills and video. Tried to focus manually and that didn't work either. Half pressed shutter release got beep beep green box indicating Focus took photo was horribly out of focus. It appears that it will not adjust focus for me. Any advice or help would be greatly appreciated.
App 4.0.1
ver 01.01.0203
RC 01.03.00.00
I don't know, but you show the VPS box in red so maybe if you locate it somewhere where the (rear?) VPS sensor isn't being triggered then the camera focus might work as it should?
Just my WAG. Good luck!
Ok thanks for the reply, will try. I have taken photos while flying in a clear area and the images are still blurry. Both on the display and in the final image also. the auto focus never makes the adjustment it should.
Still not having any luck with camera focusing on the screen,video or images. Does anybody have some advise or things to try and fix as opposed to sending it back. I have only had it for 2 weeks and all other features work perfectly. Maybe because this is new to me I'm missing something simple. As I said it did work the first day that I used it. Thanks
Are you tapping to focus? Is the green square visible when you do? If it does not focus when you tap the screen, it's probably got issues, likely mechanical.
Thanks for your advise on this issue. I did a reinstall on the djigo4 app and now all works fine. I was tapping to focus or half pressing shuttle release down to get the green zoomed in box, but it still was out of focus all the time, even on the display while flying. I hope that the reinstall has permanently fixed the issue though.
src72
