No it can't be set any higher in assistant. But once flying you can go up to tree height for example and cycle the S2 switch from middle to lower position 5 times and that will set a new home elevation point. It will give you quick green flashes to confirm that although it may be hard to see. So whatever altitude I reset in the air, RTH altitude should be about 60 feet above that. You can also reset course lock direction in the air with S2 switch.
Ok thanks, I wasn't sure.
I am blending my p1 and p2 basic memories together.
happens after you get my age a bit...
