- Joined
- Jan 9, 2018
- Messages
- 6
- Reaction score
- 2
- Age
- 21
Are you only allowed to fly at 400ft?
And if not how do you change the limit from 400ft to a higher number?
Just click on number and change,onscreen message comes up asking if you agree or disagree,if you disagree it won't change,(just means you accept responsibility)Are you only allowed to fly at 400ft?
Phantom 4 pro. Thanks! I thought that it was the limit, but a little bit back I saw a forum where a guy said if you where above a building it was 400ft plus the hight of the building. But I think he might have been from the UK, so I guess the rules ate different over there....? 400ft is high enough for me, but I was just checking to make sure I wasn't missing out on anything that I can do with my drone that is legal.???? By law (in the USA), the FAA mandates a 400ft max. You’re breaking the law by going any higher. What Phantom are you flying? All newer DJI’s with fairly recent firmware will limit you to 400ft max (I believe).
The rules refer to how high your drone is above the ground ... not how high it is above launch point.Phantom 4 pro. Thanks! I thought that it was the limit, but a little bit back I saw a forum where a guy said if you where above a building it was 400ft plus the hight of the building. But I think he might have been from the UK, so I guess the rules ate different over there....? 400ft is high enough for me, but I was just checking to make sure I wasn't missing out on anything that I can do with my drone that is legal.
The take I've gotten from by my local Feds is that the 2014 FAA Interpretation of section 336 indicates the FAA expects hobbyists to stay out of controlled airspace unless permission is granted. With regards to altitude (vertical airspace) most of the US above 1,200 AGL is Class E, in areas next to large cities and airports you'll see vertical Class E drop to 700'. To me it seems legally, in the US, you can fly up to 1,199' (or 699') feet depending where you are (excluding the AMA's 400' requirement when 3 miles from an airport). Does that mean you should? Of course not! I see 2 tings creating risk - remaining consistent VLOS and the "potential" to interfere with other aircraft as the 400' FAA "recommendation" is not being followed.
In my mind this is a mess and there needs to be a clear and concise altitude requirement for hobbyists.
(getting off soapbox)
PS - If some of you think I'm off-base here, let's discuss!
Is there a way of checking if there's low flying aircraft in your area before doing this?i would like to do it but i want to be safe as well.flight radar perhaps?In the uk the max height you can use in the drone is 500 metres. I admit I have done that when I first got my drone over a year ago and wow was it amazing but I wouldn't do it again. This is what it looks like if your interested to see how High it goes in the uk
Flight tracker is on app can look at but like most they never accurate,small planes and helicopters can appear from nowhere,if I attempt anything I got couple mates with me to act as spotters,eyes and ears open,Is there a way of checking if there's low flying aircraft in your area before doing this?i would like to do it but i want to be safe as well.flight radar perhaps?
It's not like this topic has not been beaten to death here for years. Countless threads with hundreds of posts on this issue.
I still fail to see why people think (at this time) there is a 400' limit on hobby fliers. Section 333/336 states no such thing and the FAA has confirmed in writing that this is not a limit. There certainly was a time in the past when the FAA lied to people about this.
It was all over their websites and they told people this. However, I also add in their history. They have lied about a lot of things related to drones.“Lied” may be a bit strong, but they certainly strongly recommended it and went so far as to imply that it was a rule - until challenged.
