Airport warnings
Syracuse, NY
Haven’t flown in a month or so but did today as it was crystal clear with snow cover and pictures would be nice. Started my P3P and got warnings thatI was nearby an unpaved airport. I am about 3 miles from a small strip. I was repeatedly warned during a 5 minute flight. I seem to recall a setting that allows warnings to be turned off but can’t find it any longer. You had to agree to taking responsibility for deactivating the warnings but when you did the pop up warnings stopped. Is this option still available in the most up to date softwares?
They should stop popping up after you hit the close (X) on them. I have found they do come back on if you leave and re-enter the warning area. They will also come back on after a battery swap.
Reactions: Mark The Droner
I've found the same thing... pop up window blocks the entire view screen. Check the two boxes. Okay for 3 minutes or so and it pops up again. Rinse and repeat. Does not happen all of the time but it's _very_ annoying.
Scav8tor
