FangsCPO said:Looks like a **** spider or a crab....not sure but looks cool. LOL!! Where does your battery sit?
Uncle Meat said:Just got in from my first fly. First off... looks like I got a bad transmitter cable. You have to jiggle the plug on the transmitter to get it working. If I push the connector all the way on until it locks the video doesn't work at all. I am able to push the connector in about half way and that seems to be working for now. New cable on order.
Well I really thought getting the GoPro that far forward was going to prevent me from getting the props or landing legs in frame. Alas tis not the case... when the camera is tilted straight down you can still see the bottom 1.5 inches of the left landing leg and when the camera is horizontal the props are in frame more than the old Neewer FPV skid. The simple solution is a 1, or 1.25 inch spacer between the Zenmuse mounting bracket and the Bat Wing. I could also move the Bat Wing to under the arms versus on top, that would drop the camera about a quarter inch or so. Going to have to play around with it and see what I can come u with. I was shooting in 1080 wide, but not super wide.
BTW I got 12:30 of flying in before the battery said it had had enough. 10 minutes after landing the battery had 11.13v left in it. I was able to go out about 450m with just the rubber ducky antennas before things started getting fuzzy. Can't wait to put better antennas on.
U.M.
I said: "Hopefully I can squeeze 10 minutes out of a flight..." Hopefully being the key word... I do think my f550 is too heavy at this point. What does your f550 weigh, FangsCPO?FangsCPO said:PJA if you get 10 minutes out of that bird with that landing skid......I'm switching to those.
FangsCPO said:Wow! Awesome flying time but I was rather doubtful about your batwing mount keeping the props out of view. It's a shame that we can't combine the GoPro positioning of the Neewer FPV skid and the flying time this batwing mount provides. It would be the best of both worlds. I really like the Newer FPV skid. For me I have no props in view and unless I'm flying full speed, I don't see the landing skids when looking straight down. My only complaint is the weight. I wonder how much more I can cut off from these skids to lessen the weight without ruining it?
FangsCPO said:I took up my F550 for the first time since she drowned and with the E300 upgrade installed. I didn't see any improvement in flight times. I flew it twice and I'm still flying 8:30 minutes before the first red light blinks. I re-set my timer to 8:00 minutes, once I got it back on the ground my lipo was at 34%. So what exactly is the improvement advertised by DJI regarding the E300 upgrade??
PJA said:Here are some pictures of my f550 with QuadFrame 200 Landing Gear...
I thought I'd get it up in the air today, but I had no time...
With my GLB Gimbal and GoPro (not shown) it weighs in at 2350 grams with 6400mAh Turnigy Battery (I also have an ONYX 6400mAh Battery)... I would think that's a little high... Hopefully I can squeeze 10 minutes out of a flight...
FangsCPO said:Okay....for you mathematicians out there. Here's what I've got.
If a lipo that is 3S 6400 mAh and weighs at 505g - provides 8:30 minutes flight time
What would a lipo that is 3S 8000 mAh and weighs at 580g flight time be???
PJA said:My QuadFrame weighs in at 260grams alone... I did add retracts to them which adds another 110 grams...
All my excess weight is under my f550, I guess...
FangsCPO said:Yikes...with your GoPro that far forward you may have to tie your battery to your rear arms. :lol:
badawgie71 said:That is a very impressive F550. What FPV transmitter and antenna are you using?
New to this site, here is a video of my latest FPV flight with my F550.
https://www.youtube.com/watch?v=R1mMTPEQ6h4
FangsCPO said:Oh yeah!!!! I'm back in the air after a few days of being grounded.
I tightened my prop nuts down pretty **** snug personally. I guess there is a fine line between tightening them down so hard it cracks the prop hub or not tight enough so that it comes loose. I use the German torque spec of goodentight.SammyB said:Curious to how tight you should be tightening the prop nuts. First time I'v removed the props of my F550 to balance them and the majority were pretty hard to un-tighten so when I put them back on I made them just as tight.
