A lot of people like the + for the bright screen. However, the screen is small and the overlays in the app will cover up much of the screen. The + is $300 more for a 5.5" screen, and you have no way to upgrade or change the display, it's fixed.
If you want the 1000nit bright display, it's a much better value IMO to get the
P4P without display and buy the CrystalSky 7.8" that's 1000nit. It will cost you $300 + $79 (pedestal) more than the +. The beauty of that setup is you have options. If for instance you want 3rd party apps later, you can swap out the screen for an iPad or iPhone for those times time you need a 3rd party app. The Crystalsky device also works as a portable video player and will playback 1080 or 4K video out the HDMI port, straight from the SD card from the drone, which is uniquely convenient, especially if you have a 4K TV.
Using the + controller you won't be able to:
1. Capture your screen and quickly email it to someone, because there is no email app in the device.
2. Use Litchi autonomous flight software to fly programmed missions, plotted from your desktop. Litchi can complete missions even when control signal is lost, which is unique.
3. Easily check weather, NFZs, NOTAMs in the flight area, because you don't have an internet browser in the + device. You have to use your phone or iPad for that (not a big deal)
4. Upgrade or change the display. If you don't like the small 5.5" screen, you have no options, unlike the
P4P.
5. Record the pilots voice on the device during flight (not a big deal IMO, I've never wanted to do that anyway). iPad will record pilot's voice in the GO4 app.
With the CrystalSky display pedestal, many folks don 't realize DJI offers an optional device clip for those times you'd like to use an iPad. This optional clip is $29, which clips into the standard CrystalSky pedestal.
To use CrystalSky monitor you'll also need the pedestal mount to replace the standard clip pedestal, it costs $79.
However, the + controller is compact and clean setup. You don't have to charge the display device because it uses the RC battery. I'm told it will boot faster and you don't have to launch the app, since it auto launches upon power up of the RC. It has it's conveniences, but you need to be aware of the limitations. Some owners that buy the + controller opt to by a second standard
controller for $319 with the clip for any device.
