Yaw modification by Fyod
So the Pro version is similar, but mods both yaw and roll. The board is a bit larger, but allows for 6 different settings for yaw, 6 for roll. Each setting applies to both directions so that's a total of 24 settings, but each speed always applies to left/right stick equally.
This comes in handy when you want to really fine-tune the yaw/roll and allows easier Point of Interest shots.
I use small, but industrial grade Grayhill switches.
Just wanted to let you guys know that the dual switch version is now live.
Happy to answer any questions.
When are you going to update you site? Since the new board has 24 settings overall does the yaw control have equal rotation speeds in both direction?
Yes, it does. The value of the speed is always equal for both directions.
So no matter which position you're in (off, 1-5 incrementally), left and right speed will be the same. Yaw and pitch can be different speed, since there are two rotational switches, one for pitch and one for yaw.
intertronixlabel
