Wont connect after a crash
Charleston SC
RC wont connect to drone, flashes yellow lights. Pressed te red button and moved the gimbal, Is the connection made in the camera base. If I change cameras should this clear up?
The connection is made in the vps module on the bottom of the shell. You can try this method:
If the gimbal (camera base?) is not working you won't be able to re-link the Remote to the Phantom. If you have a P3S, there is no VPS, but yes, there is that light / button, if connected to the remote, that will be green, so will the power light on the remote.
Rod
Starbase
