- Joined
- Aug 21, 2014
- Messages
- 141
- Reaction score
- 37
- Age
- 41
Ok, I tried another usb cord...now I'm in business to obtain the dat file. Is there a DAT file reader...or is it txt..
DatCon can be obtained by going here. You want version 2.3.0. But could you post your .DAT via a Dropbox link? I and maybe some others would also like to look at the .DAT.Ok, I tried another usb cord...now I'm in business to obtain the dat file. Is there a DAT file reader...or is it txt..
Well, I guess you beat me to it. If you snooze you lose.Here is the fly83 file zipped up with the warnings from healthydrones inserted in along the timeline. Interesting to see the yaw errors start at 132 seconds into the flight, compass errors shortly after -right to the end of the flight at 640 seconds.
I got my first mid flight compass error today. I did calibration on a beach few hours before flying. I always check Sensors after calibration and it was 1500 +/- 10. I took off from a house terrace and started flying over sea to nearby island. Just a bit over a minute into a flight and some 100 meters away I got red Compass error in DJI Go and P3P started to drift. I didn't panic and managed to get back safely. Although Compass error message went away and status was back to green P_GPS my AC was flying erratically but still controllable if pilot is not in panic mode. The added drama was a very narrow LoS I had for my planned flight path so unplanned drift almost took me away from LoS and probably signal range and with compass error I doubt that my drone would RTH properly. I'm attaching my flight log until I find proper internet connection to upload a .dat file. I would appreciate some insight from forum data miners.
I looked at this flight. I can't see any reason for the "compass error" that happened. BTW, it was a YAW_ERROR_LARGE. I won't bore you with all the plots that don't show anything. This flight remained in GPS_ATTI mode the whole flight; it didn't even switch to ATTI during the YAW_ERROR_LARGE event. I even checked the gyroZ drift rate. It was .08 degrees/sec; well within what I typically see. There just isn't anything to see here.
It's been speculated that the recent increase in "compass error" incidents is related to a firmware update. Usually, I'm skeptical of these firmware update explanations because, in IMHO, they rely on anecdotal evidence. But, it does seem plausible that a change has been made that causes the P3 to be more sensitive and be quicker to declare a compass error.
@neven why don't you send the .DAT to DJI and ask them what happened. I'd be interested to see what they say.
I've had my P3A for three weeks now maybe...
I've had a handful of compass errors, maybe one out of every three flights. I'll be flying along, and the app suddenly announces "atti mode" without me changing anything. When I look down it says compass error. It usually corrects itself within five seconds or so and GPS mode automatically re-engages.
I thought this was a normal characteristic of these drones. In fact, I got a compass error while flying earlier today.
I searched the uploaded .txt flightlog and found no major issues. The YawErrorLarge is likely due to a bad compass calibration. In the case of issue like that, the P3 will attempt to do part of the process itself by completing a 360 degree rotation. If it doesn't take place by a set time this is when the errors will begin to appear.
Btw, if you should ever happen to calibrate from the area where you're standing in the video, you can expect this error to place. They say nails and screws, and over head roofs can cause issues like this one.
Hey Frank.
Compass calibration was done on a beach where those towels are. Nice flat surface, no iron or steel inside pawed surfaces. Sensors were checked after calibration and they were perfect 1500 +/-10 stable. After this flight I did cold IMU, gimbal and new compass calibration and made a flight on a same route from same position. This time there was no compass errors but I had around thirty 1 to 2 sec signal dropouts in a 15 minute flights with AC in perfect LoS and distance between 10 and 1000 meters. I need to troubleshoot this bit more.
If you have perfect LoS at 3280ft you need to consider going to work for the government.![]()
Are you using the R/C with stock antenna's only? (the flat side of both antenna's need to face the aircraft at all times)
What altitude was this flight at? (you can achieve a better signal from higher altitudes)
I don't think I ever used auto takeoff or landing (not counting few critical battery autoland heart-stoppers). I take off manually, hoover for 30-60 sec and check if everything works. For landing I use hand catch.Btw, on your next flight, fly it without using auto launch or auto land. There seems to be issues at times that show up when using that feature. I'm not sure but from what I have noticed in several cases when the pilot launches with auto launch rather quickly it seems to cause a problem. Not every time, just enough to be the one factor that stands out over all others.
