What's a good vertical case for Nd filters (6)?
Looking for an oreo type packaged hard shell case that will fit 6 Nd filters. Can anyone please recommend me one? Most of the one's I've seen are laid down flat...SOLVED
DIY eyeglass case=works legit.
Which ND filters do you own?
Polarpro cinemas and just some digital concepts , so I was wondering if there was a case that stacked them like oreos.
I made my own vertical filter holders here: DIY filter holders.
You could make it for any length. I had a few narrow slots in my hard case foam and they slip in easily. I made four of them and they hold 16 filters, plus I can see what they are through the clear plastic.
Reactions: tml4191
You could make it for any length. I had a few narrow slots in my hard case foam and they slip in easily. I made four of them and they hold 12 filters, plus I can see what they are through the clear plastic.
You can easily use thermoplastic, like instamorph, to make custom slots for these. Thanks for sharing
Good job.
I use flat box and had to increase the slot size to match its size.
DIY is apparently the way to go for these filters:
Chef Vortivask
