what does the yaw endpoint setting effect and how?
I saw that there's a yaw adjustment in regards to the stick which is nice, but what does the "Yaw Endpoint" adjust? The range is 10-1000 so that's a huge range!
I see that is for the 3, but the 4 has 10-1000 value and it says mine is set at 0 right now. Guess I can start with 500 and see what it gets me
While the valid value range is different, the function is the same.
Yes, it would be a good idea to test the yaw as you're adjusting the setting mid-flight.
Reactions: krazyod21
