Vision System error
To calibrate IMU your craft has to be perfectly level and still with no vibrations, do this on a fresh start when the craft is cool, then turn your craft off then back on do not move your craft and do a gimbal calibration. When you calibrate the VPS using the assistant follow the direction perfectly, once you have centered the bird to the screen and backed up to match the squares size assistant will ask you to follow the dots, DO NOT move the craft around the screen or change the distance from the screen, keep the craft perfectly centered to the screen and follow the dot by rotating the craft on it's center axis. If you move the craft around the calibration will be screwed up. If you think you moved around start over it only takes a few minutes. I have flown at least 4 million feet since my last calibration and all is still smack on.
Don carlos
