Vision plus app
upgrade my software on pv2+v3 and the iphone app, as i have read will tell you is ok to go up when it locks 6+ sa,t mine does not do that , is there a setting switch that i miss on The app, plus tested The Dynamic home and don't work
Any Ideas
Mar
in the settings, there is a GPS signal notice that needs to be turned on. I do not know if it works at this time as they changed the firmware. I really have not played with it since.
think is on have you try D Dynamic home is there a trick to set it up?
Nope it is on there. I just tried it. You have to turn on in settings. If you try to take off before enough satellite lock, you get a warning that says not safe & you have the possibility of not getting a good home point lock.
It is right under Battery History:)
thanks will do
