Video Lag
Hi. I'm new to drones and this site. I'm having an issue with the video being very choppy. It seems to be lagging and when I watch the video it shows the lag. Any advice would be greatly appreciated. Thanks.
P3s ? Have a look and see what your recording settin is on ,can turn on and hold instead of flying to test recording ,go through each setting see which one works good,vidio size i use 1080/30fps, mp4 or mov , what sd card you got,might have a 16gb,,some sd cards bit cheap and not work to good ,try swap with another just for test,my p3 got 32gb sandisk card ,card reading speed better than 16gb
Reactions: Vanman3456
Are you seeing the lag from the sd card? What device are you using? What firmware is on it?
I'm using an iPhone 7plus. I updated to the latest firmware.
@Vanman3456,
Welcome to the forum!
How are you watching the video it records, on your phone?
Rod
Don't do that. :D
What is actually recorded is on the SD card in the Phantom, you need to play that on a computer.
Also look here for mobile device fixes.
DJI Phantom Accessories & Tips - Phantom Help
If people say there video is poor from the SD card, then I tell them to set the video recording to lowest resolution. Older computers can't process the large data files either.
Rod
Don't do that. :D
Rod
Thank you for the info. I will check the videos on the SD card and see if that is choppy. I'll let you know what happens.
Reactions: RodPad
I had this issue at one time and found it was my cable on my P3 pro. If you are using WiFi, try restarting the controller and drone.
mikeyduhaime
