USB Ports
Hello,
I am currently in the process of updating the firmware but I don't have a micro sd to sd card adaptor. Does anyone know if these updates can be done using one of the two USB ports on the phantom 3 advanced? If not what use are they for? Thank you!
You can connect the micro USB cable between the gimbal and your computer. Then, just copy the BIN to the root of the memory card. Disconnect the cable when the BIN has been copied, turn off your Phantom, and follow these instructions.
Reactions: Ollie613
