Ultimate Flight (Android)-waypoint + save/load RELEASED!
  • Thread starter Thread starter Deleted member 18853
  • Start date Start date
methinx said:
Gave you 5 stars in the play store.
Thanks for the vote; I hope I can continue to be deserving of the rating as the app progresses!
I'll bump my 4stars to a 5! Don't want a shister scamming off ya!
I've been meaning to it anyway.
Edit!
Says since I'm using a test app I can't write a review??! WTH?
Edit!
hmmmm.... i could up my 4 to ;)
done.
Edit!
Google doesn't allow pre-release apps to report ratings so the ratings are only release.
Edit!
The person in question was quite nice; I contacted him and he agreed to change the app name so it isn't so close to my app's name.
Done! 5 stars for UF and author responding promptly and accuretely to all test reports.
Best regrads Ken,
Mick
Best regrads Ken,
Mick
Thanks all; I just got the remainder of the new icons from the a designer.
Reducing pre-flight checklist
Ken,
is it technically possible to make UF app automatically put GPS on and automatically connect to Phantom wi-fi when detected? It would simplify pre-flight preparations.
Cheers, Mick
Hi
Does your app show battery load in Amps ?? Someone suggested I look at another app that saves your flight path and shows all the tele data + battery info, including amps and each of the spots on the flight path. Problem is... it looks like the apple version is alot more developed than the android.. so major features appear to be missing..
Anyways does your app provide features I described I would be interested in ? basically a way to map the battery info/amps throughout flight path.. or in real time.. either or ?
Can I install your APP and the Ilovecoffe APP both on the same tablet? (Galaxy Tab S 8.4)
Kenargo, can I install your APP and the Ilovecoffe APP both on the same tablet? (Galaxy Tab S 8.4)
I've done it on a Nexus 6. They sit side by side just fine but obviously don't try running them both at the same time.
Thanks man, did not try it because the Ilovecoffe APP says to uninstall the DJI APP, did not know if it would conflict with Ultimate Flight
It is better to use this app because it uses only official DJI SDK. The ilovecoffee app is an unsupported hack on the original DJI vision app, and because it's using the same package name you can't install the official and the hacked app togehther (their signature keys will mismatch).
justin00 said:
Hi
I have seen the battery amps and percentage in the logfile (if it's enabled in the app settings you 'll find it on your device after flight). Is also contains lat/long coordinates, so this is basically all the info you want.
I guess the only thing left is a nice graphical representation of the logfile. I asked Ken already about dashware/flytrex format compatibility of the logfile, he said it would be ready in a couple of days.
the Ilovecoffee APP has bank and turn at waypoint, my favorite way to fly
kenargo said:
I spent some time today and recorded a number of videos documenting the Ultimate Flight app.
Offline waypoint editor: http://youtu.be/S2MOldMCEzo
Ken,
In the above linked video you show the ability to move waypoints after creating them offline. What's the trick to doing this? Once I place a waypoint on my Galaxy Tab 3 it moves the whole map around if I touch a waypoint and try to change its position.
Gary
phalcon51 said:
Ken,
Gary
I've just long pressed the way point and am able to move it.
