Tilt Control Help
Hi guys,
I installed a potentiometer on the back of the controller to replace the tilt lever to enable better "on-air" tilts.
It all worked fine although a little sensitive – So I re calibrated the x1 in the software ( 10 times ! ) & now it gives me the full range of dial for a smooth tilt.
My problem is when I'm at the "full up position" (limit of travel) I get a jitter or slight kick every 2 sec or so. Tilt down a bit & its fine.
Any ideas on how to fix ? Thanks
(When monitoring X1 in the software it jumps from –1000 to –970 to –1000 without the dial being touched)
BirdMan4 said:
Hi guys,
Mine has done exactly the same thing.
If you turn it too far it "kicks"
I have noticed it also does this at different positions also.
I wonder if the 5k potentiometer is the wrong choice?
jumperswaves
