Tarot gimbal tilt problem
Hey folks,
I recently picked up a Tarot gimbal and everything is all set up, but the tilt is not working as planned. When trying to tilt the gimbal using the tilt lever on the Phanton 1.1.1, it seems to travel only a very short distance back and forth, and not in accordance with the parameters I set in the Tarot software. Stabilization seems to be working as it should otherwise. I have included some photos and video clips to show what I'm dealing with in a bit more detail.
Thanks in advance for any help! :D
Video of the problem: http://youtu.be/gO8PkWxsYr0
OI Photography said:
Sounds like you may need to calibrate the X1 channel (gimbal tilt) in the NAZA Assistant software, on the RC tab.
You my friend, are a genius! problem solved. Thank you very much.
