Tarot gimbal tilt problem
Discussion in 'Phantom 1 Discussion' started by Patrickgensel, Aug 22, 2014.
  1. Patrickgensel
    Hey folks,
    I recently picked up a Tarot gimbal and everything is all set up, but the tilt is not working as planned. When trying to tilt the gimbal using the tilt lever on the Phanton 1.1.1, it seems to travel only a very short distance back and forth, and not in accordance with the parameters I set in the Tarot software. Stabilization seems to be working as it should otherwise. I have included some photos and video clips to show what I'm dealing with in a bit more detail.
    Thanks in advance for any help! :D
    [​IMG]
    [​IMG]
    [​IMG]
    Video of the problem: http://youtu.be/gO8PkWxsYr0
  2. OI Photography
    Clarksville, TN
    Sounds like you may need to calibrate the X1 channel (gimbal tilt) in the NAZA Assistant software, on the RC tab.
  3. Patrickgensel
    You my friend, are a genius! problem solved. Thank you very much.
  4. OI Photography
    Clarksville, TN
    Nah, just seen it plenty of times before ;) Glad it's working for you now!
Similar Threads - Tarot gimbal tilt Forum Date
Tarot T2D Gimbal Tilt Issue, Not Going Up Phantom 1 Discussion Oct 4, 2014
Tarot 2-D gimbal tilt control Phantom FC40 Discussion Sep 20, 2014
Help Please - Phantom 1.1.1.1 - Tarot Gimbal v.15 - Tilt Iss Phantom 1 Discussion Aug 2, 2014
Gimbal Tilt problem tarot 2d- video in post of problem Phantom 2 Help Jun 6, 2014
Home made gimbal using part out of a tarot 680 pro Pro/Adv Discussion Oct 23, 2015
