Tablet holder.
Tablet holder*
Tried the GoPro tablet holder I saw on YouTube. Works like a charm. Highly recommend it.
Livestream iPad Mini Tablet to Tripod Mount Adapter (+ Screw Adapter) for Small Tablets and Phablets. Mount a Small Tablet or Over-sized Phone to a Tripod, or other Mount. Clamp Opens to 140 mm Amazon.com : Livestream iPad Mini Tablet to Tripod Mount Adapter (+ Screw Adapter) for Small Tablets and Phablets. Mount a Small Tablet or Over-sized Phone to a Tripod, or other Mount. Clamp Opens to 140 mm : Camera & Photo
Just wanted to share. I went through hell trying different mounts. This one works!
Those go pro mounts have a sturdy peel and stick adhesive on the back.
Reactions: 805hd
Right, and does it stick!
Put it on the front of one of my kayaks a few years ago for a go-pro cam and it's on there. No indication of coming loose. Fresh water or salt. Boats are hung up outside for the winter too.
Reactions: 805hd
Good find. I just ordered one. I already have GoPro style mounts on hand.
Reactions: 805hd
Do they do this mount to fit a iPhone 7 Plus? Looks great.
Sorry guys I didn't see any of this! If you have ever delt with gopro stickies you know they STICK.
The holder fits my shield k1 and my iPad mini. The measurements 4.5" - 5.5" are accurate. I just verified
If this one doesn't fit your device, I'm sure there are other device holders that have this threading on the bottom (tripod mount).
The one I got works very well for me.
iPad mini
I've got a similar setup but with a phone holder on a GoPro mount. I ran a cable tie from the GoPro mount to the lanyard ring just in case the sticky tape came off, at least the phone wouldn't go crashing to the ground.
Reactions: 805hd
Did you use the flat GoPro mount or the curved one? My order is being delivered today!
I just added the sticky "GoPro" type mount on my controller and I used the curved one. I'm going to make my own tablet holder following instructions on line.
Thanks for posting this though as I hadn't even thought about using this type mount.
Reactions: 805hd
Curved one, although I think you could get away with using the flat one. I took a hair dryer to the sticky to soften it up before I stuck it on the controller. Don't know if that was necessary but that's what I did. Either way, make sure its lined up cause that GoPro adhesive practically fuses to plastic.
