Switch to FCC mode in Europe, and fly miles instead of just 300 meters with P3SE
Hello. I have problem with mod app. When I tried to use 3.1.18 app, my phone open dji go and about 10 second later the application automatically turns off ;/ I have Xiaomi Redmi 4X. I don't have problems with newest version of DJI GO application.
try to reinstall
It is a pity that ignorance prevails in the answers you have received. But well, this aside.
You can stop your attempts because your Xiaomi is not compatible with v3.1.18. That is a known problem that is being worked on. I advise you to use this version of DJI Go 3.1.28 Patched.
Do you let me know what the results are? I appreciate your feedback.
@Peandreo - I tried to reset my mobile phone to factory setting but it did not solve the problem.
@chatikib - Thank You for trying to help me, I am download DJI Go 3.1.28 Patched, tomarrow I am trying to use it with my Phantom.
Tell me it's working the same as v3.1.18? I mean FCC mode is always on in this app?
As started the easy solution wasn't exist, so I started with second. Today I fly with the first option - if I fly with DJI GO on android device.
Reactions: danielor89
After using version 3.1.18 mod, I decided to uninstall it to try the new official version, I have not had to use the mode again since the switch remains.
There are still 11 channels in the 2.4 Ghz band.
I am convinced that the switch is in the RC not in the AC
You are half right. Switch is in the RC - and in the AC. Both device has radio transmitter - and both transmitters emission level is controlled by the mode switch, wich can be triggered only from the DJI Go app.
Reactions: sky eyewitness
Hello From Spain , the password for the archive above is 076
Why do you make a password public? If the poster (@chatikib) wanted it, he published it himself. What you do with this kind of nonsensical actions is that new modified apps will not being posted.
I also see in your further messages that you only talk nonsense. If you have nothing to say, it is better to just read!
y tu hablas como si tuvieras un tampax metido en la boca :)
Hi,
I don't understand how it is possible to have FCC when you use the patched app and then you use the official app which normally must switch to CE. No?
muskansahu
