Crank said:
Just finished running calibration on the P2. After that I powered it back up and it started with the red-green-yellow flashing. I waited about a minute and it was still flashing that code. I don't know what wrong with it. I will try running the software again.
I can't seem to find anything about this problem. Any ideas what's wrong?
Multitude of things...
The error may pop up in the phantom assist in the bottom right corner. If you have dual screens setup on the PC, check both screens.
What calibration did you do?
Could also be compass error. Check your MOD readings in the Phantom assist and make sure they are around 1200 - 1700.
Also, turn your controller on and place phantom on the box and place it outside so you don't get magnetic rebar in the ground and outside so you can get the sat counts.
If controller, then you may need to redo it in the separate RC1.2 software and redo in the Phantom assist.
If Adv IMU calibration, make sure it takes less than 2minutes to complete. If longer than that, it may not get the green ticks meaning the calibration has failed.
