Strange led signals?
I've not flown my phantom 2 for a while so I may be a bit rusty on the up to date naza led light sequence.
Basically took off and everything was fine. Then I noticed when I went in a forward/backward direction the green leds would flash twice rather than the steady once, when havering they would go back to the study 1 flash. Then when I raised altitude at full throttle the green LEDs would start flashing red above 200m. Fpv still showed a 12 satellite lock.
I couldn't find anything while searching so any help would be great.
When it flashes multiple green LEDs means throttle is not centered. The red flashes when climbing means battery was close to 1st warning, that sometimes happens under full throttle when putting battery under load.
Thanks for your help.
Was this something that has changed in an update or has always been there in Naza mode?
intertronixlabel
