Sticks won't calibrate.
Missouri
I tried calibrating the sticks on the P3S controller and I get as far as pressing start and then moving the sticks around. The % of the process stays at 0 and will not progress. Not talking about the % of the stick movements. Those are fine. But the % of the process will not go up. The only way to cancel the process is to shut it off. I tried re-linking the controller but it doesn't help. No problems with flying so I'm not too worried but it would be nice to have a calibrated controller every once in awhile. Anyone have this problem?
I get this far. I move the sticks around and after a few mins of that it's still at 0% progress.
The zero in the middle is for your gimbal up and down, after the sticks are moved up down left to right and you see the 100% in the circle then back to zero
as you moved it a few time that part is done. Next move your gimbal wheel left then right and you will see to 0% go to 100% for left then 0% to 100% right. That"s it you are calibrated. Click finish there is no % for the complete calibration steps.
Reactions: ROD PAINTER
The 100% will come back to 0% after the sticks and wheel have been returned to zero position. The 0% means it's at zero position.
I totally forgot about the gimbal wheel. I guess I forgot alot over the winter when I was grounded. I'm still relearning things. During my time out of the sky, I got an iPhone which has some difference in the Go App. During stick calibration, it does not say anything about the gimbal wheel. I just connected my old Android phone to try it again and the Android app goes through every step including the gimbal wheel. Thanks for the help. Hopefully I can retain this information this time lol.
I have just recieved a controller for my dji spark and it connects to the rc and phone. however i cant fly with the rc. Tried callibrating the rc(aircraft is off) but the sticks dont even move. I can use the rc to control the gimbal and the function buttons work. I can only fly the drone with the phone and not the rc. I even tried otg cables and thers no signal to the phone, but it connects fine over wifi, yet cant fly. Please help
jeetbuzz360
