Source for remote control ribbon cable locks/clips
CT, USA
Website
www.rcpickups.com
Hi all. I needed to tighten the 7mm nut that holds the tablet/phone mount on my P3 Advanced remote tonight. While carefully splitting the cases the ribbon cable pulled out of the main board. I tried to slide the black locking clip back to make sure it was working but it was very brittle and broke. Same goes for the clip/lock at the other end of the ribbon cable under the USB cover which I tried to slide back before I split the cases. Does anybody know where to find these little locking clips? They're both broken in 2 pieces so I need new ones to reassemble the R/C. It's a GL300C if that helps. About 1:09 into THIS VIDEO shows one of the clips I need. The other clip is on the other end of the ribbon cable. I'm not opposed to buying the entire cable or even a cable kit if necessary.
Thanks very much.
Rob.
