Main Board Ribbon Cable Connector
Does anyone know where to find a replacement 32 pin 0.5mm spacing flat ribbon cable connector on the Advanced remote controller main board (see attached picture)? I believe it is called a FPC connector.
fpc-connector.4464
The picture is from the USB module, however, there is an identical connector on the remote's main board. The connector on my main board is damaged and no longer locks in the flat ribbon cable.
I ordered and tried a connector from Digikey:
XF2M-3215-1A Omron Electronics Inc-EMC Div | Connectors, Interconnects | DigiKey
xf2m-3215-1a.4465
The ribbon cable fits and locks in. However, the solder pads to secure the connector to the main board do not align with the ones on the connector.
Thank you for your help.
William I am having the same problem, did you ever find a fix?
fpc-connector.4464
xf2m-3215-1a.4465
William I am having the same problem... Did you find a fix?
Reactions: Saldivar Engineer
Trying to revive the LiOn battery I had to unmount the controller and the ribbon cable came out from that FPC connector, now I can't put it all in.
Already tried pulling it with tape but nothing.
Could someone say if the fix it's to replace the ribbon cable or the connector?
Marcoo1
