Sony RX100 II Wifi Extender ?
Bogotá Colombia
I want to install the Sony RX100 II(290grs) in the PV, Sony has an APP to control shutter from Cel devices but the range is only 10Ft, be possible to add range extender to control the camera but more like 1000 ft range? Has anyone tried this? as this repeater http://www.ardrone-flyers.com/forum/vie ... php?t=2224, if the Phantom V camera has wifi extender, is not possible to add one to the sony rx100 II? any advice
The Vision isn't really a platform that lends itself to modding - by removing the Vision camera with its FPV and telemetry link you lose most of the functions that make it what it is, and the stock gimbal doesn't lend itself to mounting anything else. You may be better off with a V2 Phantom (non-Vision) and then coming up with a gimbal/mounting solution for that?
Hi Pull Up, realy I need to know if is posible setup a range extender for the Sony RX100II as the range extender in the vision to get 300mts Wifi shutter control over the camera, as it, thanks for comments
You would cause serious interference issues with the vision camera if you attempted to run both cameras at the same time, unless you were shut off the visions wifi all together, then what's the point of having a vision? Anyway you could use any wifi range extender to further the range of any wifi device.
Hi, Ben the idea is put only the Sony RX100II in the PV for best photography and use de WFI to control the camera (Shutter and Zoom) this process can´t work in Pnantom 2 (no vision) cause interference with RX, in the Phantom Vision not because RX is 5.8Mhz this is the point, I sow in youtube guys working witn an extender called Amped SR10000 with ship Drone and Ipod touch, Control an signal video.
This setup from drone expert may be of interest to you. It's an FPV setup on a phantom v1 using the Sony RX 100
Inflight Demo showing it mounted and running.
http://www.youtube.com/watch?feature=pl ... 8bDmSeMkRc
Installation video.
http://youtube.com/watch?v=qSwxQrkDITU
With the Drone Expert setup you can use the regular Phantom 1 or a Phantom 2 (non vision) as it includes an FPV setup / transmitter and remote shutter. You can view the full specs of the system from the product page here. It's pricey though.
http://dronexpert.nl/product/dji-phanto ... converter/
Another option if you want to go on the cheaper side and use the Sony's wifi for control. The new Phantom FC40 is a Phantom 1.1 with a 5.8 transmitter instead of the 2.4ghz. It includes a camera running on 2.4ghz wifi you can simply swap with the Sony. It's also under $600.
You can use any range extender to exten the wifi range of the Sony camera. Any will do the main difference between extender are their max speed capabilities and how many antennas they use as well as what wireless standards they support such as A B G N or the new AC.
Installation video.
You can use any range extender to exten the wifi range of the Sony camera. Any will do the main difference between extender are their max speed capabilities and how many antennas they use as well as what wireless standards they support such as A B G N or the new AC.[/quote]
Hi Ben thanks for your comments, The Dronexpert setup is not an option for my, I Have the Phantom Vision TX and RX 5.8 Mhz, Video Signal in Droneexpert and others is 5.8 mhz, and I want to control the view and shutter from my Phone or ipad with the Sony APP.
hi was this resolved? Has anyone had success getting sony rx100 2 wifi to work at distance?
We tried this method with a high quality range extender, however still couldn't get a usable distance. However we now have our RX100ii set up nicely. Check out our set up at viewtopic.php?f=9&t=32521
I'm not sure, but one of my customers is now selling a method to at least control the shutter with the 7th channel; http://droner-systems.myshopify.com
[youtube]https://www.youtube.com/watch?v=6_9xwHbNOB4[/youtube]
I had a similar thought to this thread previously, and went to some lengths to try and find the antenna inside my Samsung NX-1100. Unfortunately, I couldn't find it, because I had difficulty disassembling the camera. If someone else was braver, maybe they could do the same with the RX-100?
DonT
