Correct, at the time of that post I had not returned to the location where I had problems connecting and staying connected. And to be clear, the problem I experienced was that I was not able to connect the P3 to the app. And also, the one time I did manage to connect, moments later, I lost that connection. I was able to bring her in though. My problem was not a "no signal" problem. That would imply that there is a connection to the app but none to the RC. I had a connection to the RC.So you did not goto the location where the problem occurred?
Did you ever think it was simply the location? I can't fly across the street at a school... No signal nothing every time I go but down the road at a park 5 mins away I can fly as long as I want with no trouble.
Did you try a different location far enough from the problem area...
Edit... You sure you were not in a no fly zone? It just seems weird you trash the fw now it's working?
The remote was upgraded also at the time I was having the problem with connecting with the app. I too couldn't get into camera view. The app didn't recognize that my P3p was there. Sounds like you're having the same problem. Not sure about reverting back to the prior FW on the RC. I didn't try that as tech support only mentioned the uninstall, reinstall FW on the P3.Had you upgraded the remote and if so can you revert it back to previous firmware? Do you have to have camera view active in the GO app to revert back? I can't get into camera view - it keep bringing me back to "How to Connect".
Disconnection issues plague my P3P since the latest firmware update.
Since then, turning on the RC, then the aircraft, doesn´t work, the app won't connect.
I have to reset the aircraft for it to connect.
Happened twice, the two times I used it since the update. Never happened before.
On top of it, today I had the app suddendly disconnecting while operating normally for 5-10 minutes.
I was 5 feet away from the quad.
No more telemetry, nothing except the "disconnected" warning above.
I'd say this latest firmware is a killer, literally.
How did you re-link the tx/P3?I had the same no signal problem after upgrading , someone said re link the tx to the p3 and that seems to have fixed it, used to go wrong every flight, but tonight did a full battery with out a problem
