Re: getting all the firmware and downloads
ccase39 said:
If you have seen some of my posts its obvious that I am new. I have a Phantom 2 vision coming in next week. I got the instruction manual via moderator of this site and a big thank you to him! I have done lots of research on these and I try and find posts here that answer my questions before I post. ONe thing I could not get clear by reading posts on this board or reading the instruction manual is the downloadable content and firmware I need to get from DJI. Can someone give me a run down on this? What do I need EXACTLY to make sure I have everything and am up to date. What is Naza? why would I want it or not want it?
Thanks!
Naza control and Vision control is a part of the vision's programming. You can Enable naza features right there on your computer when you setup your Visions options. Naza allows you to enable IOC (intelligent Orientation Control), Homelock and Courselock. Once these features are enabled, you can select them by switching S2 to mid position (courselock) or botton position (homelock) You need to read or watch videos on what it does for you.
http://m.youtube.com/watch?v=P9tncWssRns
Also, you'll want to set the S1 switch (right side of TX) to GPS/ATTI/RTH... Depending on conditions and antenna reception, its advisable to learn to switch between these first two modes for safe flying. Again, watch some videos on how the Vision flys in "Attitude" mode. BEWARE... Never use MANUAL mode unless you are an extremely adept pilot, as this mode is fast and very responsive, with no GPS or attitude stabilized. (i have my "MANUAL" mode completly disabled in the software.)
I would thoroughly read the manual, any questions or confusing terms should be searched for, either here or the internet. Simon Newton (pull-up) a member of this forum has quite a few videos that explain in greater detail all of the features. He and Geert are both veterans with these craft and can help with any questions as you go.
The waypoint system is part of the app you download in your phone or tablet. Make sure you understand RTH altitudes and other details of Waypoint flying as it is important when you cannot see your Vision while flying in this autonomous mode. It is important to keep track of revisions and apps... As they are somewhat dependant on each other. A mismatch in firmware and app could be a cause for a crash. This forum is a good resource as to the benefit or pitfalls of revisions as they are released and tested.
(I personally never upgrade my Vision firmware until i've read about others who have... Just to verify their is no critical bugs to work out.)
Keep your battery data pins clean as they seem to be the biggest contributor to crashes other than pilot error.
Ask questions on here, and search the internet for info on almost any topic concerning DJI Phantoms/Vision or Vision Plus.
The first thing you will need to do... And you can do it now, is setup an account with the DJI website so you can download the appropriate software to your PC. Once your Vision arrives, you'll be ready to update its firmware and revisions.
You will need the Windows driver pkg (if you are using a pc and not a mac)
Then you'll be ready to load the dji assistant, you connect your vision to your pc and start the software. Follow the prompts.
WARNING!... Never unplug or plug cables into or out of the Vision while the Vision is powerd up. Always shut the Vision battery off before disconnecting or connecting cables
Welcome to the forum.... Happy hovering.
The Rookie
