slight crack on props
SEA
Had a tip over last night while landing, because ground was uneven. quad tipped over to her left side and two props dug into the grass.
Didn't do anything about it and I flew again a couple of minutes ago. Went back to clean out the props of dirt and realized that one of the props had a really small crack on the tip, probably the result of the tip over from last night but I flew mine fine minutes ago.
Is it safe to continue using this prop? Or should I retire it?
Seal it up with some superglue. It's probably out of balance anyway because you have chunks missing to go along with the crack. Superglue will make up for the missing plastic from those chips.
This is all of course only if it's life and death that you get this thing back up in the air. Honestly I'd just toss that one and replace it.
Will cause vibration, replace it.
akinproplumbing
