Simulator...
If you just want a general R/C sim that also has quads I suggest, use, and love Phoenix Flight Sim. It’s a great product and they don’t nickel n dime you after the purchase for add-on. They are free!!!
I am not having much luck getting Phoenix going BigAl07. Is there a link you could supply for me to get into the right area of their website?
Aussie Paul. :)
Son Matt, (works in IT for Ambulance Victoria's help line) is getting it organised. He just messaged me asking if I had a USB to 3.5mm lead to go from PC to controller. I have both ends and can make one if I knew which pins are used for the simulator. I would think (dangerous says Matt) that the + and - volts would not be used. Anyone know?
Aussie Paul. :)
Aussie Paul. :)
Last time I used a simulator I just plugged a 3 pin headphone lead into the trainer port on the RC and plugged the other end into the microphone socket on my laptop
Aussie Paul. :)
The biggest problem you may have is that the phantom RC’s don’t have a trainer port (where the 3.5mm plug would go)... I use the realflight SIM with spectrum and futaba remotes I have, they also supply a controller (dummy remote) to work with their software. It also good- Phoenix I have heard is likely equal or better however I’m not familiar with it.
This is the underneath of my Phantom RC.
Aussie Paul. :)
While I see that the port might be able to carry the data I have my doubts that the DJI Tx will give the right protocol to work with the Sim. I hope I'm wrong because it would be awesome using your DJI remote with the Sim.
Ok, thanks. I thought someone had some success via PC mic input.
Aussie Paul. :)
I did but i cant remember the name of the simulator program i used
I've got a 3.5mm jack into the instructor port of the handset connected to the mic input of my pc, using a bit of software it converts the signal to control inputs, I will see if I can find the YouTube video I got this from
you need smartpropoplus, and heli-x7, software, both free, plug the cable in as above and calibrate the smartpropoplus to your controller, then run heli x7
