Hi Everyone, where would I source a pc/laptop simulator for my Phantom 2 vision + please?
Aussie Paul.
Aussie Paul.
If you just want a general R/C sim that also has quads I suggest, use, and love Phoenix Flight Sim. It’s a great product and they don’t nickel n dime you after the purchase for add-on. They are free!!!
Son Matt, (works in IT for Ambulance Victoria's help line) is getting it organised. He just messaged me asking if I had a USB to 3.5mm lead to go from PC to controller. I have both ends and can make one if I knew which pins are used for the simulator. I would think (dangerous says Matt) that the + and - volts would not be used. Anyone know?
Aussie Paul.![]()
The biggest problem you may have is that the phantom RC’s don’t have a trainer port (where the 3.5mm plug would go)... I use the realflight SIM with spectrum and futaba remotes I have, they also supply a controller (dummy remote) to work with their software. It also good- Phoenix I have heard is likely equal or better however I’m not familiar with it.Son Matt, (works in IT for Ambulance Victoria's help line) is getting it organised. He just messaged me asking if I had a USB to 3.5mm lead to go from PC to controller. I have both ends and can make one if I knew which pins are used for the simulator. I would think (dangerous says Matt) that the + and - volts would not be used. Anyone know?
Aussie Paul.![]()
Your DJI remotes have a trainer port?Last time I used a simulator I just plugged a 3 pin headphone lead into the trainer port on the RC and plugged the other end into the microphone socket on my laptop
Cool- you are good to go.... that’s a trainer port. We don’t see them in the later phantoms with lightbridgeThis is the underneath of my Phantom RC.
Aussie Paul.
View attachment 102211 View attachment 102212 View attachment 102213
If I had to guess- hobbyking... just search for USB RC trainer cable and you should find plenty...Hi, where did you get your lead and do you have a part number for it please?
Aussie Paul.![]()
It seems it works (Phoenix and P2 FC).... Connect V2 controller to PC via trainer portWhile I see that the port might be able to carry the data I have my doubts that the DJI Tx will give the right protocol to work with the Sim. I hope I'm wrong because it would be awesome using your DJI remote with the Sim.
Ok, thanks. I thought someone had some success via PC mic input.Mate the PC end is USB and the remote end it’s 3.5...
Aussie Paul.![]()
