Here's a receiver question; when I bought my 14SGH, it came with a receiver. The antenna's are kind of short-but, this is going on an F550 with 800mm arms, so I don't know if the length of the antenna's will be a problem. Currently my 14SGH is programmed with version whatever is on the front page.
I'm currently running EZ UHF on the F550, and it's set in Tradional Mode on the RC page of Naza, and I have another remote with the EZ UHF transmitter....I would like to remove this set-up completely.
If I decide to go with this Futaba Receiver-R70008SB, do I need to change it over to D-bus before installing? I saw somewhere, that you needed to push a button somewhere to set the "mode" of the receiver.....I have no clue what the default is.
Also, it came with a set of wires; one end plugs into the S-Bus port on the bottom of the receiver, then there is a on/off switch, and was looks like a JST battery plug, and another plug-what's this for? And, what voltage battery can it handle if I need to plug it in to change something? I have a 2200mah 11.1 volt battery in a remote with a JST plug on it.
So-lets assume I just pull out the EZ UHF, and put this receiver in....what plugs into what, where? My remote is already set, I believe and would work without issue with the P2 settings posted here...I think.
So, the only thing I think I need to do is 1 plug from S-Bus to wherever on Naza, and provide this with power? Push the bind button, done?
Also-I know the antenna's are short and you can get longer ones-but, I don't see any way to open up the receiver..no screws anywhere, and I don't want to break it. Short antenna's may not be ideal..but, since the 550 is so open, I don't think it's a big deal-is it?
OH-how do I hook up the Telemetry that this receiver and the remote are capable of sending/receiving?
