Saving dji Go settings for 3p3
VA
Hello Folks,
I am installing my Go app settings in my P3P, today. After I get them set, or whenever I want to change something later, what saves those settings to my system? Do I do an extra step to save them?
Thank you very much,
Terry
As long as your Phantom is connected to DJI GO, the settings will be saved automatically as you set them in DJI GO.
Reactions: Digdat0
Wonderful! Thank you.
Terry
Do the shut down sequence in this order to make sure the settings are saved:
1. Exit the DJI GO app.
2. Power down the aircraft.
3. Power down the controller.
This makes sure any changes made in your settings are written to the 'hidden SD' card onboard the Phantom.
Thank you. What should I see when I open the Go App on my phone the first time? Is there a log in process? If so, what information will it be?
Terry
You'll need to login with your DJI account.
Also, is there a list of tablets specifically for the 3P3? Do I need cellular like I did for the P4?
Thank you.
You can use the same tablet. A list of the best devices can be found here.
All Phantom models can be flown without cellular.
Thanks for everything.
Terry
