It has nothing to do with the drone code.Hi I use my mobile phone, the 40mtr setting is to clear the trees beside my garden and the 120mtrs is the maximum height setting. Someone suggested it might be something to do with the drone code? not sure he meant on that one.
I have now tried everything suggested with settings nothing seems to work I have set the RTH high at 30mtrs and the max height to 100 mtrs.Ok, thanks I’ll let you know.
I have just linked my old broken drone to my controller and it flew exactly as it should 300 yds away hit RTH and it came back landed on the spot.Hi I think the problem is the model no on the controller is GL300C the model no on the drone is WM330A
Welcome to the forum!
"The setting for avoiding trees is set at 40mtrs."
Where do see this setting at?
"when I command RTH the drone goes up to 120mtrs."
How do you know it goes up to120mtrs?
Rod ..
Hi Rod I’m sorry I’ve got a bit lost on this forum!@Falcoray, the link that @Meta4 shared?
You won't believe what is in the data.
We have been here a while, look at our number of posts, etc.
If you need help obtaining, the info, many here will help.
The pay is not good here, its helping somebody and we still learn as we go.
@Meta4, is my list of the top 10 on the flight data provided. I can easily come up with 25 top members.
Rod ..
BTW, its your turn.![]()
If you want help, try what was suggested in Post #6.I have tried everything suggested ...
No idea where to go from here.
Thanks I have a problem in that I deleted the app on my iPhone and started again, I might have the data on my iPad I’ll check thanks.If you want help, try what was suggested in Post #6.
Hi Rod I’m using my iPad which I attach to my controller to record my flights. Can I download a short video on this forum?@Falcoray , I'm happy I didn't scare you off.
Sharing the flight data would have a lot of facts, reality it is going to be something new for you to learn.
My thoughts now, take a screen shot of where you see any of these RTH settings. Then post them here.
Are you using a PC on this forum if so, Windows or Mac?
Rod ..
Hi I missed this earlier I think I now have to avenues to try. Thank you.You have the right remote, 300C isp for P4. You can do a factory reset on the problem drone using DJI Assistant 2 for Phantom. And /or clear old flight logs and cache files from that unit. How-to is available on-line Google and youtube
Just had another thought I still have myJust pics, a simple screen shot, picture is a good start.
Videos, you need upload etc, then share the link, could be on, one drive, gdrive, dropbox, YouTube, vimeo.
You use the attach files to do that.
"Are you using a PC on this forum if so, Windows or Mac?"
That was the most important question for myself.
Rod ..
I’ve just had another thought I flew my old broken camera less drone yesterday, it is the same model as the new one, and it behaved perfectly. It was about 400 mtrs away at a height of 100 mtrs hit RTH and it came back landed very close to where it took off.I don’t use a pc I only use my iPhone or iPad.
